Stretch is limited inside the block editor. How to modify?
syanchuck
syanchuck
I am trying to stretch out Relay Block Contact A1 (see Image 1), however I am able to stretch it only to limited distance |(see Image 2). How to modify the stretch properties to make it possible to stretch out more?
(The file is attached.)
Image 2Image 2
Image 1Image 1
syanchuck
That is the CAD file of the relay.
Thanks in advance!
Libbya
You didn't attach the file to either post.
syanchuck
Second trying.
Libbya
You cannot adjust a linear parameter past zero with its own grip.  Reverse the parameter if you want to eliminate that limitation.
syanchuck
Thank you very much! I will check it and will let you know if I have more questions.
syanchuck
Solution is accepted. Thanks!
