Help With Function of Spline Within Block
michael.craigmiles8UE4G
Hello all, I am running into an issue with the functionality of my block here. The desired functionality is for a smooth arc to transition from point A to point B (see poorly drawn attachment). I am currently using a spline to achieve something close (screenshot attachment) but the midpoint of the spline is fixed to where it was placed in the block so unless the curve falls along that midpoint, we get the issue we see in the screen capture. I have searched far and wide for a way to make the middle fit point of the spline stay in the middle based on the distance of the end points but had no luck. Another point grip with a stretch in the middle of the spline is a possibility, but I would like to avoid this in order to make things cleaner and easier. I have attached my current state of the block for reference, thanks in advance for any help.
akhtar4223
Check the attachment...If this works for you.
