stretch attribute with sliding door in dynamic block. equally
waseemtarik
waseemtarik
hi there, I have made a dynamic block for sliding door, but I have an problem when I stretch the width or height, the text or attribute get messed-up. can someone please help me with this by screen shot a video with the right actions to apply. as I have couple doors to make it dynamic block.
see attached.
thanks
Libbya
eVERY ATTRIBUTE NEEDS TO HAVE A UNIQUE TAG.  iF YOU WANT THE VALUES TO ALWAYS DISPLAY THE SAME, THEN USE A FIELD IN THE SECOND ATTRIBUTE.  i ALSO FIX A COUPLE OTHER ISSUES.  sEE SCREENCAST.
waseemtarik
@Libbya is there another way of not having a field inside the text. so drafters won't edited by mistake?
thanks it helps me a lot but just if you could please have another method of not having a field it'll be perfect.
Libbya
If you have a set of specific attribute values, then yes.  If you want the attributes to be able to be any custom text, then no.
waseemtarik
@LibbyaI still have a problem when I stretch it, please let me know what should I do to let everything follow the doors, all the grips
thanks
I have attached the door.
Libbya
There is no reason to repeat all of the attributes, linework, and parameters/actions for the second visibility state.  The following screencast shows diagnosis and repair.
rushabhthakkar_910
Yes... I too think there is no need to Repeat all of the above Mentioned.......
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
