Problem when I change depth of block
When I change depth of block, cant switch drawers and dors? Any idea how to solve this?
Attachment under 🙂
h_s_walker
1. Your start positions of the Point 1 and Point 2 parameters are in the wrong position. They both need to be set at 1,1 each.
2. You don't need to chain the Point 1 parameter. All it is doing is giving a number for your lookups.
3. The basepoint parameter you've added is what will mess up your block. The explanation is below
When you place a basepoint parameter in a block it becomes the new 0,0. Since you've put it at the end of your block, the two point parameters are no longer at 1,1
Since you've placed the basepoint parameter in the stretch the 0,0 is constantly going to move.
If you want the block endpoint to be at the corner you should have started to draw it that way.
See the attached drawing for a working copy of your block
Howard Walker
Left Handed and Proud
lena.talkhina
Hello @Anonymous !
How it's going? Did @h_s_walker helped you?
If so, press the "Accept as a solution" button - it will say "thank you" to a person who helped without words and also help others to find a solution faster.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
