Dynamic Blocks - Multiple sub blocks/ Visibility states
subramanyam.perivenkata
I have a electrical module drawing which has multiple internal options. The module block has 8 channel with jumper positions to be shown with each jumper having 3 states. similarly each channel has 3 types of possible wire connections. The jumper position and wire connections are not related.
need help in creating a dynamic block where the user can select the jumper/ wire options individually for each channel.
I am using AutoCAD Electrical 2018.
h_s_walker
Search for DOUBLE LOOKUP. There are plenty of examples which will get you started
Howard Walker
Left Handed and Proud
Double lookup does not work for me. Attaching the drawing with the requirement. Hope to get a solution.
