Stretch Action Maintain Offset
I'm trying to make a block for a window where the rough opening is at an angle at the head. I need the vertical mullions to stretch independently from the horizontals, which I've done in the block; but I'm having trouble with the horizontals. Whenever I stretch them the offset changes. Is there a way to lock the lines at the distances I need? I've tried every parameter and constraint in the block editor.
faragello
Hi @Anonymous
the stretch command for 2 lines not able to keep the distance between them.
I think this is not allowed in AutoCAD out of dynamic blocks in stretch command, so inside dynamic so can not.
ojuris
hi
may be multiline is solution for you
That's exactly what I needed, thanks!
