dynamic block rotation - scaling
Hello, Can I manage dynamic blocks from the command line. If there is a method from the command line, you can provide information. Here's the short I want to do
1- I will draw an ellipse with an angle value.
2- Distance between two ends of ellipse
3- Giving direction to the ellipse
4- Show the angle I will set for the ellipse.
5- At the top of the ellipse the arrow and the lettering will turn along with the ellipse.
6- The front part of the ellipse is an antenna with dimensions that I want to be facing in the same direction as the antenna.
7- The inside of the ellipse scan will be done hatch scale will remain constant. I think you will understand better when you look at the photo. Good work.
fkp7057
I have attached Dynamic block file which you can control using angle & vertical rad. you just modified it as per your requirement.  hope this will help you.
regards,
FKP
Thanks for your support. I solved my problem.
