Strange action when combine stretch and rotate
truss_85
truss_85
Greetings;
I have a block which is attached that combine one rotation parameter to another then both combine to a linear stretch parameter. It is acting what it is supposed to be. When stretch parameter between 200 and 800 first rotation parameters value in properties palette going crazy. Geometry is in correct angle and agle1 value is something else. Second rotation is fine when the stretch value between 200 and 800. But when it goes over 800 it is behaving like the first rotation (geometry is right, palette value is wrong). Can somebody tell what is that strange behavior came from?
Thanks in advance
ojuris
hi!
is it what you want - see attached
I stretch only line, all other including both rotation actions add to move action
And for both rotate actions Base type made Independant
truss_85
Certainly is that what I wanted.
Thank you very much
