Store project info for use by blocks?
gccdesign
gccdesign
Is there a way to store project info, like project name, address, project number in Autocad so that a block attribute can display that data?
GChapp
Libbya
If you use Sheet Sets for defining your project then there are a variety of pre-defined sheet set properties and you can define any number of custom sheet set properties within the project for use in the manner you describe.
gccdesign
I have yet to lay a finger on sheet sets. I should look into this.
Thanks for the info.
GChapp
