Slope triangle
Slope triangle
M00M00isHungry
Slope triangle
M00M00isHungry
I've created this slope triangle. It's stretching sideways only but would like to stretch downwards as well.
Can I use the field for both of the numbers so that it can work in any scale?
or please guide me if you have any idea.
Thank you.
Brock_Olly
Added another stretch parameter to the bottom point with extra 90° rotation, seems to work.
The text doesn't move in the center though, don't know how you achieved that on the top dimension.
Edit: Seems to not work well when it gets flipped.
MMcCall402
Try this one.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
-didier-
Bonjour @M00M00isHungry
Here is my proposition without attributes to avoid regen.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
M00M00isHungry
Thank you Brock_Olly but it's a bit different from what I wanted to achieve.
To move the dimension to the middle, added move parameter for the number to the stretch parameter and set 'Distance multiplier' as 0.5.
M00M00isHungry
Thank you MMcCall402, but the number for downward doesn't corespond to the length for me.
M00M00isHungry
Thank you -didier-  I never thought about using dimention and it seems working good!
