settings changed
settings changed
settings changed
I have a dynamic block that starts out 3'x3'. I can adjust it with 2 grips to make it 30'x50' if I needed it to be. All I had to do was select the grip and type (30') and hit (Enter) select the other grip and type (50') then hit (Enter) and I would have a 30'x50' block. However now when I do that I end up with a 33'x53' block. I have a whole lot of blocks and all of them are doing this. how do I change it back?
Libbya
I think it's probably a simple issue.  If you posted the block, I could probably tell you for certain, rather than just guessing at what's causing it.
I'm fairly new to all this. I do not know how to post the block. I also
have not looked but I thought I would reply first. Attatched are a few
blocks I use. all of them are doing the same thing
Joshua Mann
Floyds Sales
187 CR 514
Berryville, AR 72616
870-545-3568 - Office
870-545-3769 - Fax
sales.floyds@gmail.com - Office E-Mail
www.floydssales.com -Website
Here are some of the blocks
Libbya
I don't see an issue.  If I select a grip and input a distance, the parameter becomes that distance.  Does it work differently for you?  Please give as much description as you can of the issue.
It works different for me. It used to work like how you are describing.
Before if my block was 2'x3' but I wanted the 2' part to be 100' I would
select the grip for 2' and enter 100' and it would be 100'. But now if I
select the grip for the 2' and type 100' I end up with 102' instead. I have
started inputting the dimensions in properties but that has slowed my
workflow down.
Floyds Sales
187 CR 514
870-545-3769 - Fax
F12=Toggle Dynamic Input Mode.
