Set Array Distance or count within an instance
will.wydock
will.wydock
It has been a few years since I have messed with dynamic blocks. I am working on a block with an array based on a length that i would use as guide for sheet specs based on the Titleblock. What I am wondering is can I make the block have the ability to modify/enter values for either the spacing or number of spaces?
R0m3r014
Hi. If you can achieve what you need with visibility and lookup states.
I enclose a block that I made with 20 divisions, in case I need more, we will add the corresponding visibility states and indicate their distances in the distance parameter and in the lookup tables.
I hope I could help something. Luck
Sorry for my English that is terrible. I will try to improve. Greetings from Mexico.
