hi everyone!
I'm currently developing a dynamic CAD block of an architectural section cut symbol. I saved my progress by creating two versions of it:
Now the text attributes remains horizontal as I rotate the section block. But something weird happens when I start stretching the ends of the block - and the annotation text becomes misaligned. I tried multiple combinations to try and resolve this but for the life of me I can't figure out what's needed to be done.
Attached are the blocks in question. Any help would be greatly appreciated - thank you!
Solved by j.palmeL29YX. Go to Solution.
Try the attached suggestion.
Jürgen Palme
Even if that was not your question - if I were you I'd add a small improvement as demonstrated in version_4. But that's your choice ...
Jürgen Palme
This is exactly what I was looking for, thank you! I learned quite a bit from tinkering with your block and checking the attributes, appreciate you for sharing the DWG. file.
I actually made one small change to your version 4 by adding another stretch parameter ("Stretch 3") and creating two stretch actions set to a Distance Multiplier of 0.5. This way I can make sure that the origin stays at the centre of the cut symbol even though either side are stretched. Attached is the file for others to tinker with as well.
thanks again!
You don't need to add those two stretches. If Distance3 has it's "Basepoint" set as MIDPOINT the 0 of your block will always be 0
Howard Walker
you're right - i ended up modifying my block again to only have a single Distance parameter. This works much more better - thanks for the suggestion!
