Scaling ring with constant thickness
Message 1 of 10
how to scale ring with constant thickness but different diameter?
Replies (9)
Message 2 of 10
Libbya
Always post the block file.
Message 3 of 10
Libbya
Here's an easy way.
Message 4 of 10
Thanks a lot!
I have one more problem,
I want to make a dynamic hole in this ring...
Any solutions?
Message 5 of 10
Libbya
I could do it with a couple wipeouts.  Is that acceptable?  Is the block going to placed where wipeouts would create an issue from blocking the display of linework/text behind the block?
Message 6 of 10
wipeout is acceptable but how to adjust its shape?
Message 7 of 10
Libbya
I tried getting it to work with wipeouts and the hatch kept losing associativity.  I then switched to constraints and seem to have gotten it working.  Here's the file.
Message 8 of 10
Libbya
Here's the step-by-step on creating the constraints version.
Message 9 of 10
Libbya
I noticed that the center mark disappeared in the process.  I'm not sure why, but I've found center marks to be a bit glitchy when combined with dynamic blocks.  Here's how I'd deal with it - this picks up where the last screencast ended.
Message 10 of 10
excellently but I have to associate ring diameter and hole diameter with other variables.
Before, I did it from Chain Actions but now?
