Dynamic Blocks Forum
Scale/Stretch Question
2 REPLIES 2
arkelec
233 Views, 2 Replies
I have a block for a square section (and rectangular) with a shaded fill as can be seen in the screen grab below:
I want to be able to vary the width & height (X & Y), so have set up two stretch actions.  All good.
I can also stretch the shaded fill, but the ratio of fill area needs to match the increase in width & height.
For a width & height of 100, the distance to the point where the angled edges meet is 0.25 x length selected (from the top left corner).
If I use the stretch function only, the ratio is not maintained.  Is there a way of achieving this?
I've had a look at some of the solutions on this sub forum, but none seem to solve this specific question.
Thanks in advance.
Tags (3)
2 REPLIES 2
Libbya
in reply to: arkelec
Yes, if I understand you correctly it can be done easily.  See the attached file.  I added a chained gripless point/stretch at the knee of the hatch boundary.  That point/stretch stretches the knee vertex.  I added a stretch action to each linear parameter so that it stretches that point and edited the stretch actions' distance multiplier to be 0.75.  I also adjusted the stretch windows of your prior stretch actions so that they did not include that knee vertex.  Let me know if you have questions.
arkelec
in reply to: Libbya
Ah, that makes perfect sense & solves the problem perfectly.
Thank you so much.
AutoCAD Inside the Factory
