I would like to select all of the blocks with the same attribute value in order to assign a part number to all parts of the same length. This value is based on a field which pulls the length of the centerline (a polyline consisting of straight and radial sections) of the part to produce the flat length. I had no problem getting the attribute to update (after a regen) with the correct length when a stretch action is performed.
My problem is that I can't find a way to select all the parts with the same field-generated value. I've tried several lisps, including one by Lee Mac (here), but to no avail. Even if I copy the text directly from the Attribute Value in the block's Properties window and paste it into the command line when prompted, I cannot get it to work. It seems that AutoCAD does not recognize the text since the field displays as "######" (with gray text fill to represent the field) when you go to edit the attribute by double clicking. Is there a way to achieve this goal? Does anybody have experience filtering attributes populated with fields?
Will O
