Good Day Everyone!
I've been diving into the forums all morning for a potential solution to a hurdle I am faced with a dynamic block I am working on. Unfortunately, I haven't been able to find a solution or alternatively, I perhaps haven't been able to understand the solution. Your expertise would be greatly appreciated, either answering directly, or pointing me to a thread that has an applicable solution.
The Goal:
Create a module block for drawing titles that has extents that are stretchable to a maximum of 4x the base vertical dimension and 4x the base horizontal dimension. The block should also have a scale action using a lookup that will scale the whole block by a factor equivalent to typical drawing scales.
The Challenge:
The block is functioning exactly as I'd like it to, until it is scaled. The increments set for our stretching actions do not scale with the rest of the block.
The Request:
A way to set the stretch actions so that they will adjust the increments with the scale or an alternative way to setup the block that would achieve this. Visibility States won't work as we would need to duplicate text attributes.
I've attached the block for your direct review. Thank-you in advance for any help you are able to provide.
