Round up an Attribute
I am using an attribute to display a design temperature in a block. I would like another attribute to display this same value rounded up to the nearest whole number.
I have played around with constrained parameters and using the ceil() function without much success. Any suggestions?
3wood
I think you can use FIELD in the attribute.
See attached example drawing.
Libbya
Yes, a formula field.  If memory serves |[att value]+0.5|.
Libbya
See the attached file.  I set the default value of the top attribute to 10 and then addede the formula field to the default value of the bottom attribute.  In the formula field I inserted an object field referencing the value of the first attribute and then added 0.49999 to it.  The result is that it will round UP to the next whole number as shown.  If a new insertion of the block is created, it will need to be jumpstarted to get the field to update on regen.  To jumpstart the block click the move grip and select a point.  It can be the same location but you need to make a dynamic action in order for the field to work.
Thanks!
