Hi All
I am seeking lisp to rotate text attribute.
In shortcut:
1) Run command
2) Click text (attribute)
3) Click ref object (line, 3d pline, text)
4) Text (attribute) rotates around text's insertion node for an angle defined by ref object
Sorry I don't do lisp, but study the attached drawing you can do it easily without lisp
Howard Walker
I most of cases I have point (on line/polly) and text. Point and text are dynamic block, but I need to align text to line. Block definition can not be changed as it is should be compliant with drawing standards
@BB8x Use the alignment parameter ringed in the image below, then you can drag and the block will automatically align to whatever line you drag it to
Howard Walker
I have lisp to rotate whole block against insertion point, but I want to rotate only text.
There is a lisp for it, but it takes a while to align single text. I have loads of them
(vl-load-com)
(defun c:attro (/ break data_input attrib->text askangle Justify qang ; local functions
adoc ss ename1 elist1 attribs^ p0 p1 p2 p3 rot cod)
(defun break (msg)
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(if ss
(foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(entdel ent)
); if
(vla-endUndoMark adoc)
(vlax-release-object adoc)
(setvar "cmdecho" 1)
(setq *error* nil)
(princ)
); break
(defun data_input (/ n pick0 ename0 elist0)
(setq n 0)
(while (setq pick0 (nentsel "\nSelect text or attribute: "))
(cond
((and
(setq elist0 (entget (setq ename0 (car pick0))))
(wcmatch (cdr (assoc '0 elist0)) "TEXT,ATTRIB")
(redraw ename0 3)
(setq attribs^ (cons ename0 attribs^))
(prompt (strcat "\n" (itoa (setq n (1+ n))) " text object(s) selected."))
); case
( t
(vlr-beep-reaction)
(prompt "\nObject selected is not text nor attribute.")
); case
); cond
); while
attribs^
); data_input
; temporary convert attrib to text
(defun attrib->text (e)
(entmake
(append
(list '(0 . "TEXT"))
(vl-remove-if
'(lambda (dxf)
(member (car dxf) '(-1 0 2 3 5 70 72 74 100 102 280 330 347 360 370 440)) ; eliminate these dxf codes from elist
e
); vl-remove-if
); append
); entmake
); attdef->text
; pause for angle while draging
(defun askangle (def / ask)
(if (not (setq ask (acet-ss-drag-rotate ss p1 (strcat "\nRotation angle <" (angtos def 0) ">: ") t 0)))
(setq ask def)
(setq def ask)
); askangle
; return justification dxf code
(defun Justify (e / itm)
(if (and
(setq itm (assoc '11 e))
(not (equal (distance (cdr itm) '(0.0 0.0 0.0)) 0.0 1e-3))
11 10)
); Justify
; make sure text is in readable angle
(defun qang (a)
(if (and (> a (* pi 0.5)) (<= a (* pi 1.5)))
(+ a pi)
a)
); qang
; here start attro
(setq *error* break)
(setvar "cmdecho" 0)
(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(vla-startUndoMark adoc)
(if (> (abs (getvar "userr5")) (* pi 2))
(setvar "userr5" 0.0)
(if (data_input)
(progn
(setq ss (ssadd))
(foreach ename1 attribs^
(setq elist1 (entget ename1))
(attrib->text elist1)
(ssadd (entlast) ss)
); foreach
(if (and
(> (sslength ss) 0)
(setq p0 (getpoint "\nSpecify base point: "))
(not (command "._move" "_si" ss p0 "'cmdecho" 1 pause))
(setq p1 (getvar "lastpoint"))
(setvar "userr5" (setq rot (askangle (getvar "userr5"))))
(progn
(entdel ent)
(setq ss nil)
(setq p2 (cdr (assoc (setq cod (Justify elist1)) elist1)))
(setq p3 (polar p1 (+ rot (angle p0 p2)) (distance p0 p2)))
(setq elist1 (subst (cons cod p3) (assoc cod elist1) elist1))
(setq elist1 (subst (cons '50 (qang (+ rot (cdr (assoc '50 elist1))))) (assoc '50 elist1) elist1))
(entmod elist1)
(entupd ename1)
); foreach
); progn
); if
); progn
); if
(setq *error* nil)
(princ)
); c:attro
