Rotating dynamic block with fixed attribute orientations
Message 1 of 24
I'm struggling with a simple dynamic block.
The block is a simple arrow with 2 attributes.
I gave the block a rotate parameter and rotate action.
This works fine but the whole block with it's attributes rotate.
I would like it when the block can only be rotated to 0, 90, 180, 270 degrees.
The attributes should always be in 0 or 90 degrees orientation.
When the block is rotated in 0 or 180° the attributes should be rotated 0°.
When the block is rotated in 90 or 270° the attributes should be rotated 90°
Anyone know how to do this?
thanks!
Replies (23)
Message 21 of 24
h_s_walker
That should say chained not changed. Me dumbo
Howard Walker
Left Handed and Proud
Message 22 of 24
Thanks for your help. I am believe I understand my options.
Message 23 of 24
TIANADXEVL
I'm having the same problem with my block.
I want my simple annotation tag arrow to be easily rotated 90, 180, and 270 degrees.  But everything I try for rotation ends up separating the arrow's polar strecth fuction from the arrow itself.  Can you help?
I basically just want the straight arrow to rotate like "Tag Before.dwg", and the arrow stretching part to work like it does in "Tag.dwg"
Can anyone help me?
Message 24 of 24
tim.duzan
Thanks for this video. I didn't know about the Lookup feature so this taught me a bit more on my dynamic block knowledge.
