AutoCAD Geometric Constraints
gosbee30
gosbee30
I have blocks with linear geometric constraints and wanted to know if there was anyway of filling in the liner constraint values from an external source like excel
jimmy_alexander
Hola Soy de Colombia,  quisiera saber como hacer esto tambien...
gosbee30
I can't understand what you wrote. I only know English
jimmy_alexander
Hola, quisiera algo asi.. como lo logro?
https://www.youtube.com/watch?v=vFi7UZ4ZlcQ
Emmsleys
Hi @gosbee30
I believe you can export data from dynamic blocks to an excel format. I'll need to test a few blocks to see if you can push data to fill in linear constraints.
In the meantime you can also look over the following it may be helpful.
http://aucache.autodesk.com/au2016/sessionsFiles/20626/11850/handout_20626_GEN20626-Chadwick-AU2016....
Post back if you have any new questions or have already found a workaround.
Sarah Emmsley
Technical Support Specialist
