- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am creating a block where I would like to have a rotate parameter rotate relative to zero degrees even if the entire block itself is rotated, is there a way to achieve this?
Example below, the first image has the block placed at zero degrees with the white box rotated dynamically to 33.2 deg. from the red line.
The second image has the entire block rotated but as you can see, when the white box is rotated dynamically it is relative to the red line, what I want is for it to always be relative to zero degrees indicated by the yellow line.
Image 1
Image 2
