Rotate Multiple Attributes Within Dynamic Block
cale_olsenJL9RQ
cale_olsenJL9RQ
Hello, I'm trying to create an elevation block that when rotated the "view" text stays both upright, and in the same position relative to the arrows, I've made sure the "rotate" action only selects the "Position" parameter, but when chaining these together it seems to break the block.
If I delete "position 2" then the block works fine with only "position 1", but I would like to have text on both arrows.
If anybody has any ideas on how to tackle this, that would be great!
h_s_walker
I'm not sure what you were doing wrong, but the way you were going about it is correct. See the attached drawing
Howard Walker
Left Handed and Proud
cale_olsenJL9RQ
Thanks Howard! I wonder if it was because I had the 2 attribute blocks defined the exact same, whereas you have the attributes named "view" and View1" differently. Thanks for helping me out!
h_s_walker
Yeah that could be the problem. All attributes in a block need to have a UNIQUE tag.
Howard Walker
