Rotate and Move for a flush opening
samuelb8Y56V
samuelb8Y56V
Hello All,
I'd intended on making a 3D kitchen cabinet but got distracted on how the door would work, so I've been trying to develop it in plan. The issues is I can't think of a way to both rotate and move in one action. I know I could use vis states and have 3 states open, closed and a jar but that's no fun. So if you could contribute to the DWG in anyway that would be great. I have used another users block as guidance/inspiration but can't find the post where I nab it so can't credit it them.
j.palmeL29YX
Are you looking for something like this?
In a 2D environment you can simulate such and similar behavior (as you see above), but if you want to animate the door in a 3D model you will need a better appropriate programm (as Inventor  or other parametric 3D Software). AutoCAD is not suitable for such tasks.
Jürgen Palme
samuelb8Y56V
This is great, I appreciate the modelling capabilities of ACAD are limited, could you possibly provide the block or an explanation of how you did it?
j.palmeL29YX
Attached an exampe. It's done using Parametric constraints.
If you're not familiar with this topic and need more explanation let me know.
Jürgen Palme
samuelb8Y56V
I have some experience with parametric constraints but only in partnership with user parameters. I don't really understand what you've done, I recreated you block but I'm obviously missing something that allows the "door" to follow the correct path. Any guidance or tutorial would be great I've attached what I was able to reproduce.
j.palmeL29YX
HTH
Jürgen Palme
samuelb8Y56V
Wow! Great video and it was nice to see your troubleshooting process too. Thanks for the help.
