Rotate action with XY Array
TomHia
Message 1 of 10
TomHia
AC 2021. I've attached a block which works mostly fine except for one thing.
What's wrong?
Adding "Rotate" parameter/action in order to add a handle for full block rotation causes the "Array" action to fail.
What I want my block to do?
It's supposed to:
a) Stretch the outer rectangle two-way.
b) Move the text with 0.5 coefficient two-way (maintain center).
c) Array the inner rectangle with the specified values.
d) Rotate the whole block using the "Rotate" action while allowing it to array afterwards.
I think the XY parameter can't be rotated which causes the strange behaviour.
Does anyone have an idea how to achieve this seemingly simple yet elusive behaviour I want?
Thanks in advance!
Replies (9)
Message 2 of 10
h_s_walker
Don't use an xy parameter for the array
Put in another two linear parameters. One for the horizontal array and one for the vertical array and chain those to the stretches. Linear parameters can be rotated.
Howard Walker
Left Handed and Proud
Message 3 of 10
TomHia
thanks for the tip but it won't work since you can have only one array action per geometry. I need the array to act in two directions independently and form both a "vector" and an "array".
This is the result I'm getting when applying chained distance parameters. Depending on the setup the pseudo-array just ends up alongside different side of the stretched rectangle.
Message 4 of 10
h_s_walker
Can you post your latest attempt as a drawing
Howard Walker
Message 5 of 10
TomHia
Of course!
Attached below. Mind that I had to draw a second identical "inner" rectangle for it to work, cause as I mentioned before - you can't associate a second array action to the same geometry.
Message 6 of 10
h_s_walker
Unfortunately I can't see an easy way around it. However, if you use the alignment parameter the block will rotate to whatever line you "attach" it to and you will still be able to use the xy array
Howard Walker
Message 7 of 10
TomHia
Thanks, I'll explore it tomorrow.
One would think this sort of use case is prolific and should be doable...
Message 8 of 10
TomHia
I just got what you meant by the latest suggestion. It's the same as if I just rotated the block with a command instead of the handle. Doesn't really cut it, I'm better off with the command.
Thank you for the attempts and taking a look into the case!
Other ideas and suggestions are still very much welcome in the thread.
Message 9 of 10
h_s_walker
The only other way it will "work" is if you do the array first and then rotate, but be aware if you try the array again it will go back to being orthogonal
Howard Walker
Message 10 of 10
TomHia
@h_s_walker Exactly. I've tested it beforehand and come to the same realisation 🙂 Far from ideal.
