Simple dynamic block behaves differently depending on which grip is adjusted first
mike_eddy1
mike_eddy1
This is the first dynamic block I've created and it behaves *almost* exactly the way I want it to.
I'm hoping you experts can help me with 2 issues: (1) grip behavior and (2) convert individual block line/arc elements into a single polyline.
ISSUE 1: GRIP BEHAVIOR
The desired behavior is for the block height to always align with the "Height" grip and the block width to always align with the "Width" grip.
  • TestA: The block behaves correctly if I make any adjustment at all to the "Width" grip before I make an adjustment to the "Height" grip.
  • TestB: The block behaves incorrectly if I adjust the "Height" grip before I adjust the "Width" grip - this results in the block height and width no longer aligning with the grips.
ISSUE 2: CONVERT TO POLYLINE
I would like to apply a linetype to the block with Linetype Generation enabled, but right now the block is composed of individual line/arc elements rather than a single polyline. When I try to recreate the block using a polyline rather than individual line/arc elements, it behaves even more poorly than in the examples above. Can anyone see a reason why this block cannot be composed of a polyline?
JBerns
@mike_eddy1,
Try this please:
  • Edit the block with Block Editor
  • Select the Height Linear Parameter
  • Chain Actions = Yes
  • Number of Grips = 1
Save and Close the Block Editor.
Test.
Let us know if that works for you.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
mike_eddy1
Thanks for looking into this, JBerns. I still encounter the same scaling issue even when I make those changes. Did this fix the behavior for you, though?
mike_eddy1
I found a solution. Instead of using a combination of a Linear Parameter and Stretch Action for the "Vertical" grip, I should have been using a Vertical Constraint. Now that I've made this swap, the block is behaving correctly and I was able to use a polyline rather than individual line/arc elements.
JBerns
Glad you found a better solution, Mike.
CAD Administrator
mike_eddy1
On the off chance someone runs across my post and needs my revised block, I'm attaching it here.
This block ALMOST meets my needs perfectly, except I cannot apply a Rotation Parameter and Rotate Action to the block, maybe because I have too many Geometric Constraints in place?
If anyone can help me to make use of the Rotation grip in this block I would greatly appreciate it!
