I would like to create a rotatable line (red) to move in a 360-degree radius with the other line (blue) that follows in alignment with the red line. From either the North or East points so that I can make the lines acute or obtuse with the use of a parameter within a dynamic block whilst staying the same distance apart from one another.
Any suggestions?
Make your block so the red line is 0,0 then add a rotate parameter set and add both sets of lines to it. See the attached drawing
Howard Walker
Hi "Hwalker" appreciate the assistance but that's not quite what I'm looking for, was hoping to make it be capable of stretching into a different angle by using the rotate function. I'm not sure if it exists but would be awesome.
If you want to stretch and rotate change the rotate stuff for a polar parameter and polar stretch.
If you only want one blue and red line to rotate remove the others from the rotate action.
Howard Walker
