Dynamic Blocks Forum
Rotatable lines and alignment with lead line.
3 REPLIES 3
joshuaXEDHB
182 Views, 3 Replies
I would like to create a rotatable line (red) to move in a 360-degree radius with the other line (blue) that follows in alignment with the red line. From either the North or East points so that I can make the lines acute or obtuse with the use of a parameter within a dynamic block whilst staying the same distance apart from one another.
Any suggestions?
Labels (2)
3 REPLIES 3
hwalker
in reply to: joshuaXEDHB
Make your block so the red line is 0,0 then add a rotate parameter set and add both sets of lines to it. See the attached drawing
Howard Walker
Left Handed and Proud
joshuaXEDHB
in reply to: hwalker
Hi "Hwalker" appreciate the assistance but that's not quite what I'm looking for, was hoping to make it be capable of stretching into a different angle by using the rotate function. I'm not sure if it exists but would be awesome.
hwalker
If you want to stretch and rotate change the rotate stuff for a polar parameter and polar stretch.
If you only want one blue and red line to rotate remove the others from the rotate action.
Howard Walker
Autodesk Customer Advisory Groups
”Boost
