Hi Folks,
I'm reworking our current title blocks and revision blocks, but I need some help. I want to create a revision block that keeps a permanent record of all revisions within a project, but only keeps the 4 latest revision bars visible on the drawing, with an empty revision bar the top of the stack (5 total rev bars). I could use visibilities to make that happen, but I wouldn't be able to have it position itself on top of the title block with each change.
There is a Project info block under the title block, and the rev bars above the title block. The title block will eventually fill the space between the two. Any ideas on how to make a revolving rev bar?
Thanks in advance 🙂
Thanks for the advice!
I fought with it last night and figured it out using a visibility parameter on multiple blocks with attributes that reference the main rev block. Works like a hot ****! Now we can keep a complete record of all revisions within a project and only display the ones we want to 🙂
Cynthia
