Reset Block Failure - Stretch and Move
07:44 AM
Hey all, I am trying to make an adjustment to a dynamic block.
The issue at hand is that there is an array of holes with two columns. The idea is that the 2nd column to the right is to stretch 1:1 with the depth so that the hole spacing stays inset from the front and back at the correct distance.
When I apply the parameter and action to the hole for that column it works fine. Either using Move or Stretch, it will move to the right as needed when the depth is changed, but when I use "Reset Block" then try changing the depth it will no longer move that 2nd column at all and stays stationary.
How can I fix this bug? Thanks!
