Cabinet Array with Resize
DesignAlias
DesignAlias
Community Visitor
Community Visitor
Is there a way to make a cabinet array that will also allow you to adjust the total width of the whole block once you've stretched it to the amount of cabinets you want?
This has probably been asked before bit I've been searching for an hour and I can't find anything... so please feel free to link me to other solutions.
If you're looking to variably control the array spacing if the cabinet width changes I do not know of a way to do that. The Array action cannot have a defined user variable set.
If it was possible you would just set it up to count the number of cabinets and take the run length and divide it be the cabinet count. If you wanted to have a standard width set you can have the height be adjustable, but not the cabinet width. Did a test with a 20" width cabinet and it allowed for an infinite run quantity based on the run length.
