Replacing dynamic block with visibility state and changes
krishnandynBQY9Z
krishnandynBQY9Z
Dear sir,
I want to replace dynamic blocks in many  by redefine from tool pallete, But I am not getting replaced with modified length of the same visibility state. If I add some text then reflects after redefining. Is there any setting to replace/redefine the block with same modified length in the same visibility state.
Krishna
timothy_crouse
If you want all the visstates to be the same follow the steps below:
you can select (1) block
-Right Click and select simular to select all the other block of the same type
-Gotto Properties and look for the visstate property and set it to the desired visstate.
