replacing dynamic block with modified length with same visibilty state
krishnandynBQY9Z
krishnandynBQY9Z
Dear Sir,
I am trying to repalce/redefine modified block length with same block name wblocked in different folder. The modified block length is not reflected in. Is there any setting to update the length of dynamic block.
Please find attached files.
Libbya
Are the block definitions different, or is the only difference that the dynamic parameter values have been changed?
Redefining the block changes the block definition from the old to new version.  It does not change dynamic parameter values unless the parameter has been deleted or name changed, etc... and if that is the case, it will revert to the as-drawn state within the block definition.  That does not seem to be what you want.
Why don't you just select all of the blocks you want updated (using select similar or QSELECT) and change the parameter values globally within properties?
If you would like all future insertions to match the updated values, then change the values within the tool palette tool properties.
