Dynamic block stretch/angle constrain
leticia.campanelli
leticia.campanelli
Hi there,
I wonder if someone can explain or show me how to create a dynamic block with two points of stretch and keep everything parallel.
I tried a few different combinations with constraints, but nothing gave me the final result I was looking for.
I have attached the block for reference.
The idea is to stretch the sides to different heights and keep all lines parallel.
Any help would be appreciated.
Brock_Olly
I think it's possible with a lot of different constraints and a lot of work, since this is quite a difficult block to make.
Your mitre angle changes which means each line has to have actions assigned to it individually.
Question is how often you're going to use this block? Isnt it better to draw your outlines first and then apply the 8 offsets needed? Maybe with a LISP routine
Libbya
I misinterpreted your post.  Ignore this comment as I cannot delete it.
MMcCall402
There's an old AutoCAD object that seems perfect for this. An MLine.   It's like a polyline with multiple offset lines that go with it and act as one object.  The MLine style also has the option to display the miter line at the bends.  You could then just use the MLine command to draw it directly or use it within a dynamic block and reshape it with linear parameters with stretch actions, although the Mline already has grips at its angle points you can use for reshaping it.  The yellow objects below are Mlines.
Commands:  MLINE, MLSTYLE
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
leticia.campanelli
I completely forgot about Mlines. it is perfect thanks!
