Reorder Lookup Parameter with Parameter Manager
gustavobernardi
Message 1 of 9
gustavobernardi
A way to rearrange the position of lookup type parameters? I tried the manager parameter, but they are not listed... TIA
Replies (8)
Message 2 of 9
I am also interested in a answer to this question. I thought that they were listed and had disappeard but now I am wonderin if they hadent been listed to begin with...
Message 3 of 9
I found this lisp which apprently can do it but I keep getting an error when it runs.
https://forums.autodesk.com/t5/dynamic-blocks/rearrange-custom-block-properties/td-p/2541829
Message 4 of 9
This does actually appear to be working just not on the block I needed it for...
Message 5 of 9
gustavobernardi
It is not a direct solution, but a solution ... You can reorder the parameters in the block inserted and then use the WBLOCK command to send the changes to the file...
Message 6 of 9
akaterr55
Be sure to Resetblock your DB before running Move-Properties-Eng.lsp!  It will error unless the block is in its native state...
Message 7 of 9
Julio_Soto
pretty much what I was looking for. Works on almost all my blocks, but some not so much.  Come on AutodESK!
Message 8 of 9
aitorm
yes, it is not universal 😞 for some blocks it is not working
Message 9 of 9
h_s_walker
For which of your blocks is it not working? Do they have attributes in them? If so you need a different set of commands.
See the link below
https://forums.autodesk.com/t5/dynamic-blocks-forum/reorder-custom-properties/m-p/8778558/highlight/...
Howard Walker
Left Handed and Proud
