Rectangular pipe dynamic block
I made a dynamic block for a rectangular pipe which can be changed via parameters and actions. I can change the height and width and it works just fine, but when want to change value D for the thickness the bottom half does not link with the value inserted.
I want to keep the base point directly on the bottom of the block for easy usage.
ojuris
You can't use Scale action for rectangular pipe. You must use 4 stretch actions (one for each side). And you don't need parameter ID.
boicottms
I dont' know how to deal with the rounded corners, but did you try constrain?
see attached sample: two side an thickness parameter, the offset is realized with constrains
