Message 1 of 8
12:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I could use some help here. I have a dynamic block with 3 move actions, 2 flip actions, a rotate action limited to 4 angles, and a visibility parameter w/ 2 settings. I want the 4 angles and the 2 visibilities to control everything. I setup a property table to set all the parameter combinations for the 8 desired configurations.
I get the desired results except that I want to be able to manipulate the parameter grips to get the desired configuration. Right now, as soon as my table get all the combinations in it, the parameter grips are no longer showing.
I tried doing away with the property table and going to lookup tables but was unable to get what I wanted.
Any suggestions?
