Dynamic Blocks and Constraints
Trying to make a dynamic block. How do I use constraints such that when I stretch the plate (marked (P)) to the right and/or down, my basepoint (Position 1) will remain at the intersection of the right edge of the plate and the centerline (Intersection shown circled in blue below).
Someone please help.
Thank you,
Brian
Clarification: Position 1 is not a basepoint but a position parameter which I want to assign a move function to.
I created a point and used coincident constraints to keep it at the intersection of the two lines. Now I just need to figure out how to link the position 1 parameter to this point
Libbya
Unless there is more to the block including some other difficult action (e.g. arcs) then I wouldn't use any constraints at all.  I would use dynamic parameters and actions as their behavior is much more direct and consistent.  Dynamic parameters/actions are like pulling a cooked spaghetti noodle.  Constraints are like trying to push it from the back.  Post the actual block for better assistance.
