- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I HAVE MADE A BLOCK WITH A FLIP AND ROTATE PARAMETER WITH MAXIMUM AND MINIMUM ANGLES....
I INCLUDED ROTATE PARAMETER IN THE SELECTION SET OF FLIP...
PROBLEM : IF I ROTATE AND THEN FLIP THE BLOCK...THE BASE ANGLE OF ROTATE PARAMETER IS CHANGED AND SO THE MAXIMUM AND MINIMUM ANGLES ARE ALSO CHANGED....
IS THERE ANY SOLUTION FOR THIS...
I AM ATTACHING THE SAME BLOCK WITH THIS....
