Polar stretch parameter and Polar stretch action Problem
wael6URAQ
Message 1 of 23
wael6URAQ
I have a problem using the polar stretch parameter and polar stretch action in my dynamic blocks
This is the original shape of my block:
I added two main parameters to modify the length and the width of the block as shown in the next two green clouds:
Another secondary polar parameter is chained to the main two parameters  to move the line marked R4 and rotate it automaticly to result the follwing:
This is the hoped result so that the mark and the line lenght and the angle are parrallel as shown
also the point for stretching its dim line should be at the middle of the mark as shown.
unfortunatly the result is as the following:
I attached the block
Please help to fix this problem.
Replies (22)
Message 2 of 23
j.palmeL29YX
Using a block with constraints you can do >>this<<
- change the value of d1 to 4000
- change the value of d2 to 6801
- change the value of d3 to 2000
Your R4 is not necessary for such modifications.
BUT I'm not sure which values you really want to "drive" the geometry.
Do you really want d2 or (perhaps better) the horizontal width of the shape?
Do you want drive this three dimensions or do you want as result, that the R5 line always touches the both lines at the midpoints? (Then is one of dimensions d1, d2 or d3 not necessary. It's your choice which of them you delete).
Your description leads to an over constrained geometry: If d3 is always the half of d1, then the R5 line will touch the both lines always in the midpoint (regardless of the length of d2).
You should exactly define, which values you want free to change, and think about, which values are the geometrical result.
Please clarify ...
Jürgen Palme
Message 3 of 23
wael6URAQ
thanks a lot for your effort and advise
Unfortunately this is not what i want but in the same time I cannot explain what i want
I ll try to record a video for what i want and upload .
Message 4 of 23
wael6URAQ
in the meanwhile can you please explain why The Attribute named (R4) and the 2 fields below are not rotating correctly with the line???
Message 5 of 23
j.palmeL29YX
In the meantime my next attempt.
Jürgen Palme
Message 6 of 23
wael6URAQ
Many Many Thx
Message 7 of 23
wael6URAQ
THANKS ALOT
NOW THE ATTRIBUTE TAKES THE LINE ROTATION PROPERLY
BUT NOW THE ATTRIBUTE IS FIXED
IS THERE A WAY TO BE ABLE TO MOVE THE ATTRIBUTE  RIGHT LEFT UP DIWN LIKE THE POINT PARAMETER WITH MOVE ACTION LIKE WHAT I USED IN MY ORIGINAL BLOCK??
Message 8 of 23
wael6URAQ
ALSO PLEASE I NEED TO NOW HOW DID YOU MAKE THE PARAMEERS INVISIBLE??
Message 9 of 23
j.palmeL29YX
In >>this<< post some days ago I tried to explain some "secrets" using parametric constraints in Dynamic Blocks.
HTH
Jürgen Palme
Message 10 of 23
j.palmeL29YX
@wael6URAQ wrote:
IS THERE A WAY TO BE ABLE TO MOVE THE ATTRIBUTE  ...
It should be possible I think. But before I try to implement that let us know, if you really need/wish a free movement in all directions or perhaps only along the line to which they are parallel? Or "fix" them near the middle of the line (as I did with the RR2 )?
By the way, please do not shout! (that is, do not write the whole text in capital letters. That reads terribly 😞 )
Jürgen Palme
Message 11 of 23
wael6URAQ
First I want to apologize about the shouting issue really didn't mean any disrespect.
Second Yes I need free movement for all attributes and dimensions because i use this type of blocks in more crowded structures which need neeting to avoid clashes.
Message 12 of 23
wael6URAQ
example1
Message 13 of 23
wael6URAQ
example2
Message 14 of 23
wael6URAQ
example3
Message 15 of 23
wael6URAQ
My main concern is to fully understand the behavior of the polar Strech action and why it is not acting as i wish when it is chained to another parameters from start and end in the same time as my blocks.
Message 16 of 23
j.palmeL29YX
I think now I understood what you need. >>Click<<
Have a close look at the attached file to analyze what I did. I hope you see the principle, even if I added only the "actions" for two of the attributes.
(After changing the Length and/or the Width you must of course regen the file to update the values of the fields. The attributes are rotated in a correct manner. With the point grip you can/must move the attributes to an appropriate position.)
For a better compare of both blocks my block patest-3 still includes your old geometry. And I did not yet change the constant property of my attributes to yes. but I think such trivia you can correct yourself.
Jürgen Palme
Message 17 of 23
wael6URAQ
thank you sir this is almost exactly what i need.
it is not clear to me which point did you use to associate the polar stretch parameter (start or second)
also what about the point for moving the dimension line......i tried it but it is not rotating to be in the middle of the dimension line text as it should be
Message 18 of 23
j.palmeL29YX
@wael6URAQ wrote:
it is not clear to me ...
>>Here<< you can see what I did.
But I must admit that this is still far away from the functionality shown in your examples. And also I don't know how to make the dimensions moveable as you expect.
Where are the examples coming from, CAn't you contact the author of these files and ask him what and how he did these blocks? For me, I reached the end of my knowledge  😞
Jürgen Palme
Message 19 of 23
wael6URAQ
I m the author of this blocks 🙂
I created them from scratch and i have many more.
I managed to reach this level by trial and error and not by fully understanding the behavior.
Some times it works by 2 polar stretch at the start and at the end and using multiplier 0.5 both.
Some Times  by 2 polar stretch at the start and at the end and using multiplier 0.5 at one and -0.5 at the other.
Some Times  by 1 polar stretch at one end and multiplier 0.5  but he other end i use stretch only with multiplier =1.
Some Times  by 1 polar stretch at one end and multiplier 0.5  but he other end i use stretch only with variable multiplier value by trial and error.
Some times i reverse the stretch and the polar if it doesnot work .
any way thank you sir for your time and effort
Message 20 of 23
wael6URAQ
I think you thought that i m not the author of this blocks because of my question:
"it is not clear to me which point did you use to associate the polar stretch parameter (start or second)"
I only asked this cause i noticed that it matters and doesnt give the same result
And I dont know a way to reach this information from a ready block
Some times by mistake i choose the start point and put the stretch frame around the other which gives very strange behaviour and i dont have a way to check this except deleting and redoing.
