My door block won't work after using Flip action
nadia.ribeiroXZP64
nadia.ribeiroXZP64
I'm trying to create a personalized door in my work.
But I can't figure out, for the life of me, what am I doing wrong
Every time I incorporate a flip action, things go sideways
I've attached the block and the results I'm having
Any help is very much appreciated!
chrismunt
Nice block. You almost had it. Where you went wrong is that the stretch action was not actually attributed to the flip actions.
To fix your block all I did was go into the block editor and change the value of "BACTIONBARMODE" from 1 to 0. I could then see your flip actions (with a lightning bolt next to them) and right click to "action selection set -> modify selection" then just clicked the stretch actions (with a lightning bolt next to them) to ensure they were included in the action.
Hope you understood & hope this helps.
Chris
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
nadia.ribeiroXZP64
Chris, you're a life saver!
Thank you so much for fixing it and taking the time to explain the steps
