Hi, I'm trying to create a dynamic block for inserting pipes and their connection curves at the ends.
The problem I stopped on is on curves. I would like to create an action that allows it to vary the angle from 0 (absent) to 45° to 90°, for both ends separately.
I have already used the visibility parameter to display or hide a text indicating the diameter.
Any help please?
I'm using Autocad LT 2023
Thank you!
Solved by ojuris. Go to Solution.
Thank you very much, seems it's working, but I have not understood some lookup actions. Can you please expain me how to set it up into a new block?
In the web you can find several videos which explain that.
e.g.
and surely others too.
HTH
Jürgen Palme
