Dynamic Blocks Forum
pline in dynamic block
5 REPLIES 5
michelle1x_watkins
305 Views, 5 Replies
I have a dynamic block that I want to be able to scale and have the pline width remain the same for all scales, can I do this?
5 REPLIES 5
Libbya
in reply to: michelle1x_watkins
Maybe.  Post the block if you would like a clearer answer.
Libbya
If you want the polyline width to remain constant regardless of it being scaled, then place a chained point/stretch at each vertex (the stretch actions should act on the pline).  Then scale the point parameters (and not the pline).  If you want any further assistance, then post the block.  If I misunderstood your request, then post clearer details of what you want to accomplish.
j.palmeL29YX
in reply to: Libbya
@Libbya
Cool idea - as long as the pline doesn't include arc segments.
(Perhaps therefore you said "maybe" and asked for the block ?)
Jürgen Palme
michelle1x_watkins
in reply to: Libbya
the plines are arcs, so this probably won't work right?
I just read this, I agree sounds like won't work if it's an arc.  posting block isn't really necessary, either you can have a thickness or you can't.
Forma Design Contest
