Dynamic Blocks Forum
Parametric Constrain 2 Blocks
10 REPLIES 10
Message 1 of 11
757 Views, 10 Replies
I wonder if anybody knows how to parametric constrain two dynamic blocks together, so that if you dynamically stretch the one block,
the other blocks moves with the stretch?
10 REPLIES 10
Message 2 of 11
ojuris
why it can't be 1 block?
Message 3 of 11
Charles_Shade
in reply to: ojuris
Excellent point.
OP: Do you know that you can tie multiple Actions to one Parameter?
Example attached. Open in the BE and then Test Block if you don't care to INSERT it into a DWG.
Message 4 of 11
in reply to: Charles_Shade
Hi Charles,
Thanks for your reply, no, I did not know that you can tie multiple Actions to one Parameter, I will definitaly test that.
We also came across Mulltiple visibility, but could not figure that out as yet (and the visibility states are just going to be to much from what I could gather
I know that you could constrain two blocks together, but then you loose you visibility grip which defeats the purpose.
Thanks again for the time taken in responding.
Regards
Message 5 of 11
in reply to: ojuris
Because we use the blocks in creating different scenarios, so it is better to have it as seperate blocks (5 blocks instead of 50 blocks)
Message 6 of 11
ojuris
may be you can post some example?
Message 7 of 11
in reply to: ojuris
Sorry it took so long for me, but have been a bit under the weather.  At last here is an example of what we want
to do.  This drawing contains 3 blocks (dynamic) which have to move with the the widening of the road on the road.
Regards
Message 8 of 11
ojuris
what is possibly scenarious?
Message 9 of 11
Libbya
Here's the approach I would take.  You'd have to add the various stretch actions.  See attached.
Message 10 of 11
in reply to: Libbya
Thank you  so much, exactly what we wanted.  Still haven't figured out the Multiple visibility?
I'll play around some more.
Message 11 of 11
Libbya
Forma Design Contest
