Dynamic Blocks Forum
Need help with dynamic block that has fixed holes on the ends but array in center holes
3 REPLIES 3
knnth_
213 Views, 3 Replies
I'm new to creating dynamic blocks and after watching tutorials and reading forums I can't seem to figure this one out..
Trying to create a dynamic block where the two end holes are fixed when being stretched either way and not simultaneously. While also having the center holes (red) arrayed and evenly spaced with each other and with the two end holes.
3 REPLIES 3
JBerns
in reply to: knnth_
Please post your drawing. It will be easier for someone to assist if they can see what you have so far.
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
j.palmeL29YX
in reply to: knnth_
Something similar to the attached attempt?
Jürgen Palme
knnth_
in reply to: j.palmeL29YX
This is exactly what I was trying to do. Thank you so much!
Forma Design Contest
AutoCAD Beta
