Need Help With Creating a Dynamic Block From an Example
miacuviz13
miacuviz13
Hello guys, I have this dynamic block that I need to recreate on my own, but since I am new to dynamic blocks (I only ever worked with regular ones) I have a hard time figuring it out. Is anyone free and willing to help me better understand this one or explain how they made it in the first place?
Thanks in advance, it means a lot!!!
The block in question is attached below!
Libbya
Your block has multiple visibility parameters within it.  That is not possible using stock AutoCAD.  The only way I know to do that is with using Visibility-add-eng LISP routine that hasn't worked for the last 10+ releases of AutoCAD.
https://forums.autodesk.com/t5/dynamic-blocks-forum/visibility-add-engine-lsp-where-can-i-find-it-an...
miacuviz13
Thanks, I will look more into it!
