Visibility States TIP - (if you still struggle with assigning graphics to them like me)
hencoop
Advisor Advisor
hencoop
Hello all,
I finally figured out a good way to avoid the frustration of separating graphic elements to their respective visibility... and identifying the missing graphic elements that are needed and the duplicates that are not needed.  Perhaps this has been suggested before now.  If so, I missed it... and thanks to them.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Libbya
Yup, I've done that for years and suggested it a multiple times on this forum.  Although, depending on the desired behavior, I would probably adjust the selection sets prior to moving them all back together.  I also wouldn't use redundant elements but rather use a single item visible in all the required states.
