I want to chain some move actions with a visibility action so that when I change the visibility state, the attributes move. The reason for this is so that when some of the attributes are hidden, the remaining move so that they are still close to the center of the block.
How do I accomplish this?
Thank you!
Solved by Libbya. Go to Solution.
Please attach the block so that we can help you out.
You can remove the visibility grip and in its place add a lookup. Use the lookup table to control both the visibility state and the position of point parameters that move the attributes.
