Move dynamic Block points on coordinates
Amriya_Exe
Message 1 of 8
Amriya_Exe
In attached Dynamic block There is 8 points I have to move them on following coordinates
0.1224,0.7129
0.6947,4.0477
1.4682,8.5539
2.3617,13.7594
3.5384,20.6155
4.3687,25.4528
4.8083,28.014
6.1623,35.9029
6.6455,38.7182
method I following in inserting points and moving manual but for bulk work is there any method to get it done another way?
On main file its I have to paste this block 40 time and I have 40X 9 Coordinates on alignment
Replies (7)
Message 2 of 8
whitney_jeff
Can you use the Divide or Measure commands?  Looks like the spacing is constant
Message 3 of 8
Amriya_Exe
No I cant.
If you check coordinates spacing is not constant.
Message 4 of 8
h_s_walker
@Amriya_Exe The only problem I'm having is I can't remember how to temporarily turn off the osnaps.
First I would place one of the objects at 0,0 and then copy it using a script file. See the image below and the .txt file attached. Change the extension of the text file to .scr and don't forgot to turn off your snaps (F3)
Howard Walker
Left Handed and Proud
Message 5 of 8
Amriya_Exe
Hi thank you for showing interest here.
This is result of your script
I think you misunderstood my problem.
Message 6 of 8
h_s_walker
I would move your block away from the 0,0, then put a point on 0,0 and run the script then move your block back to 0,0
Howard Walker
Message 7 of 8
Amriya_Exe
can you try once?
I tried to select points to 0,0 its not moving may be limit in parameter.
Message 8 of 8
h_s_walker
Ah I was getting the wrong end of the stick. I see now you wish to move the circles. Unfortunately I can't think of any way of automating that
Howard Walker
