MAKING THE OBJECTS IN CENTER OF DYNAMIC BLOCKS
Hi guys!
Can you help me out on my Dynamic Block.  I am currently developing this Door Dynamic Block.  I will be attaching the file so feel free to do look into it.  But please let me know the process on how you solve the problem.  I am really eager to learn more about the process of Dynamic blocks.
1.  My problems is that I want to make the Door Eye Viewer always on center of the Door Clear Width  but i do not know how to make it possible.
2.  Is there a way that i can make the door stretch with increments for both the X axis and Y axis.  Currently what i did is i have to stretch both the X and Y axis.  I was wondering if there is a way to do it both in on stretch.
Thank you in advance.
Regards
Arch A.
Accepted solutions (3)
h_s_walker
I can't get the arc working properly, but the other stuff was easy.
I deleted your door height parameter and added everything to the clear width.
There is a move parameter with a multiplier of 0.5 which keeps the door eye viewer central in the clear gap.
There is a stretch parameter added with an angle of 90 which stretches the door.
There is a move parameter with a multiplier of 0.5 and an angle of 90which keeps the door eye viewer central in the door.
Howard Walker
Left Handed and Proud
h_s_walker
I've updated my previous attachment. The arc now works as it should
Howard Walker
Libbya
Your arc scaling is still a little off.  The reason for the discrepancy is that the governing parameter is larger than the radius of the arc so scaling introduces a small but noticeable error.  The solution is a chained parameter for controlling the scale.
Hi hwalker,
I have looked into the CAD that you did and it works perfectly!  I also learned 2 things with your reply and now I will try to apply to the dynamic blocks that I am currently planning to do.  I hope if I can ask you again for some dynamic issues i will be having. FYI Left handed here as well!
Thanks a lot. Much appreciated.
Arch A
Hi Libbya,
Awesome video! Thank you for the video upload it was such a wonderful video to clearly clarify the issues.  I hope i also can ask you for help on some of my dynamic blocks issues in the future.
Thank you and much appreciated
Arch A
